Multiple joined components in one STL generate shell walls between components
Posted
· Multiple joined components in one STL generate shell walls between components
It's not the slicer really. If you don't combine the parts, there will be a surface between the two objects. Since STL doesn't actually define what is inside or outside (it only defines surfaces) you get weird results like that.
I've taken a screenshot of the uncombined version of the file to show you what the issue is:
As you can see, there is a small gab between the two objects. This gap is caused by the tessalation (eg; It needs to create flat surfaces, so a round surface is approximated by multiple flat ones). This process will pretty much always introduce inaccuracies, which can lead to gaps like this.
The result that you see is basicly your slicer doing exactly what you ask it to do; There are two components and they are printed as two components.
Posted
Thanks @nallath for your advice, I now understand what it's doing and the rationale behind it.
As much as I've got to like Cura's simplicity and ease of use (even in Expert mode which I am certainly not!), it's a shame it doesn't have similar capability as to what PrusaSlicer appears to do, that is, see both components (it calls them parts) in the single STL and when combined, slices them both as one.
nallath 1,125
Aubs 0
