Print moved mid print on Y Axis?
Posted · Print moved mid print on Y Axis?
Hi James,
what's happened is called layer shift.
The reason is a lose pulley or a skipped belt, so you should check that. Ensure the set screws of the pulleys are tight and the tension of the short belts is ok.
https://support.ultimaker.com/hc/en-us/articles/360011598659-Check-the-tension-of-the-short-belts
https://support.ultimaker.com/hc/en-us/articles/360011490220-Check-for-play-on-the-axles-of-the-Ultimaker-3
Regards
        • 10 replies
