Cura 4.9 Freezing at initializing Build Volume
Gooddadrick
Posted · Cura 4.9 Freezing at initializing Build Volume
Any fix yet? I'm having the same issue. Idk if this is actually the cause, but I accidentally unplugged my sd card without ejecting while cura was still opened. Maybe this helps
    No, because we didn't get any information.
    it just just suddenly worked for me. I just let it be and then the error message crash thing popped up and told me to back up the configuration file and remove the configuration file or whatever it did earlier. After that, I opened up cura and it works. Though my profiles are gone now. Any way I can get them back?
    Yes, it's in this thread:
    Posted (edited) · Cura 4.9 Freezing at initializing Build Volume
    .. update ..
    Well well.. within the time it took to write my OP, cura crashed and allowed me to submit the crash report to ultimaker. Hope that helps the team.
    Performing the backup and settings wipe allowed Cura to start and set up a new profile for my printer.
    Hint, just let it keep trying to open it will finally fail with a message, may take a couple minutes.
    Edited by bnewbold
    same thing happened to me.
    but there is no submit button to actually send the error report..
    Traceback (most recent call last):
    File "__startup__.py", line 74, in run
    File "Console.py", line 36, in run
    File "C:\Users\ultimaker\AppData\Local\Temp\cura-build-4.9-exe\build\inst\bin\cura_app.py", line 241, in <module>
    File "C:\Users\ultimaker\AppData\Local\Temp\cura-build-4.9-exe\build\inst\lib\python3.8\site-packages\cura\CuraApplication.py", line 829, in run
    File "C:\Users\ultimaker\AppData\Local\Temp\cura-build-4.9-exe\build\inst\lib\python3.8\site-packages\cura\API\__init__.py", line 54, in initialize
    File "C:\Users\ultimaker\AppData\Local\Temp\cura-build-4.9-exe\build\inst\lib\python3.8\site-packages\cura\API\Account.py", line 110, in initialize
    File "C:\Users\ultimaker\AppData\Local\Temp\cura-build-4.9-exe\build\inst\lib\python3.8\site-packages\cura\OAuth2\AuthorizationService.py", line 235, in loadAuthDataFromPreferences
    File "C:\Users\ultimaker\AppData\Local\Temp\cura-build-4.9-exe\build\inst\lib\python3.8\site-packages\cura\OAuth2\AuthorizationService.py", line 78, in getUserProfile
    File "C:\Users\ultimaker\AppData\Local\Temp\cura-build-4.9-exe\build\inst\lib\python3.8\site-packages\cura\OAuth2\AuthorizationService.py", line 117, in _parseJWT
    File "C:\Users\ultimaker\AppData\Local\Temp\cura-build-4.9-exe\build\inst\lib\python3.8\site-packages\cura\OAuth2\AuthorizationService.py", line 257, in _storeAuthData
    File "C:\Users\ultimaker\AppData\Local\Temp\cura-build-4.9-exe\build\inst\lib\python3.8\site-packages\cura\OAuth2\AuthorizationService.py", line 102, in _parseJWT
    File "C:\Users\ultimaker\AppData\Local\Temp\cura-build-4.9-exe\build\inst\lib\python3.8\site-packages\cura\OAuth2\AuthorizationHelpers.py", line 115, in parseJWT
    File "requests\api.py", line 75, in get
    File "requests\api.py", line 60, in request
    File "requests\sessions.py", line 533, in request
    File "requests\sessions.py", line 646, in send
    File "requests\adapters.py", line 412, in send
    File "requests\adapters.py", line 315, in get_connection
    File "urllib3\poolmanager.py", line 285, in connection_from_url
    File "urllib3\poolmanager.py", line 234, in connection_from_host
    File "urllib3\poolmanager.py", line 247, in connection_from_context
    File "urllib3\poolmanager.py", line 268, in connection_from_pool_key
    File "urllib3\poolmanager.py", line 202, in _new_pool
    File "urllib3\connectionpool.py", line 897, in __init__
    File "urllib3\connectionpool.py", line 181, in __init__
    File "urllib3\connectionpool.py", line 77, in __init__
    File "urllib3\connectionpool.py", line 1041, in _normalize_host
    File "urllib3\util\url.py", line 300, in _normalize_host
    File "urllib3\util\url.py", line 300, in <listcomp>
    File "urllib3\util\url.py", line 306, in _idna_encode
    File "urllib3\util\url.py", line 306, in <listcomp>
    RecursionError: maximum recursion depth exceeded while calling a Python object
    Thread 0x00003d60 (most recent call first):
    File "C:\Users\ultimaker\AppData\Local\Temp\cura-build-4.9-exe\build\inst\lib\python3.8\site-packages\UM\Backend\Backend.py", line 165 in _storeStderrToLogThread
    File "threading.py", line 870 in run
    File "threading.py", line 932 in _bootstrap_inner
    File "threading.py", line 890 in _bootstrap
    Thread 0x000033ec (most recent call first):
    File "C:\Users\ultimaker\AppData\Local\Temp\cura-build-4.9-exe\build\inst\lib\python3.8\site-packages\UM\Backend\Backend.py", line 153 in _storeOutputToLogThread
    Thread 0x00000f1c (most recent call first):
    File "threading.py", line 302 in wait
    File "threading.py", line 433 in acquire
    File "C:\Users\ultimaker\AppData\Local\Temp\cura-build-4.9-exe\build\inst\lib\python3.8\site-packages\UM\JobQueue.py", line 98 in _nextJob
    File "C:\Users\ultimaker\AppData\Local\Temp\cura-build-4.9-exe\build\inst\lib\python3.8\site-packages\UM\JobQueue.py", line 124 in run
    Thread 0x000044d4 (most recent call first):
    Thread 0x000051d4 (most recent call first):
    Thread 0x000038c0 (most recent call first):
    Current thread 0x00002ca0 (most recent call first):
    File "C:\Users\ultimaker\AppData\Local\Temp\cura-build-4.9-exe\build\inst\lib\python3.8\site-packages\cura\CrashHandler.py", line 396 in _logInfoWidget
    File "C:\Users\ultimaker\AppData\Local\Temp\cura-build-4.9-exe\build\inst\lib\python3.8\site-packages\cura\CrashHandler.py", line 182 in _createDialog
    File "C:\Users\ultimaker\AppData\Local\Temp\cura-build-4.9-exe\build\inst\lib\python3.8\site-packages\cura\CrashHandler.py", line 86 in __init__
    File "C:\Users\ultimaker\AppData\Local\Temp\cura-build-4.9-exe\build\inst\bin\cura_app.py", line 167 in exceptHook
