Thanks for reply.
Yes I used cura 4.9, in fact before start print I seen the PVA not in correct position, but when the PVA was arrived in position not worked very well.
I thinks that there are 2 problems. The first the bug on cura 4.9 and the second the print core B-B
gr5 2,094
Did you upgrade to cura 4.9? If so then this is a known bug where the right hand extruder retracts too much before printing. I think a 4.9.1 release is imminent (not sure). A quick fix might be to lift the lever on the right feeder and slide the PVA further in just before it starts printing - not sure if this will work. Or go back to cura 4.8 until 4.9.1 comes out.
