GregValiant 1,141
It's about the same build size as an Ender 3 or 3 Pro. Install one of those and change the name to whatever you want.
First and foremost, make sure you know the firmware flavor. I would guess Marlin but that's just a guess.
After installing and naming the printer:
Click on the printer name in Cura and select Manage Printers then select Machine Settings. The Ender definitions have a build size of 220 x 220 so enter your 230 x 230 in the correct boxes. Double check the Gcode flavor as it must match your machine.
That should be enough to get you going.
1
TomJonSports 0
I recently just got the FoKoos 3D printer Odin-5 F3 as my first 3d printer. Im running into the same problem as Cura has no preset printer configuration for this printer. Ive been looking and have yet to find a solution to this problem. if you have any advice or a solution please let me know!
