If the layer number for that area is correct then the gcode will be correct. The problem is with the preview display, but not the slicing. Sometimes if Cura is shut down and restarted that bug goes away. I believe the bug has been reported on GitHub as well as here.
A year after the merger of Ultimaker and MakerBotQQ, we have unlocked the ability for users of our Method series printers to slice files using UltiMaker Cura. As of this release, users can find profiles for our Method and Method XL printers, as well as material profiles for ABS-R, ABS-CF, and RapidRinse. Meaning it’s now possible to use either Cura or the existing cloud-slicing software CloudPrint when printing with these printers or materials
GregValiant 1,142
