Cura 4.9 startup freeze "initializing build volume" + fix
Effin
Posted · Cura 4.9 startup freeze "initializing build volume" + fix
Cura 4.9 will freeze while loading on "initializing build volume", also reported on /topic/36785-cura-49-freezing-at-initializing-build-volume/
The problem is with ultimaker account sigh in
Fix is to delete the row "ultimaker_auth_data = ..." from cura.cfg and re sing in on application launch
  • Like 2
10 hours ago, Effin said:
also reported on
Then wouldn't it have made sense to reply in that thread?
    • 2 weeks later...
    • 4 weeks later...
    Thanks, this worked perfectly! It also preserved my profiles, so bonus.
    For those like me struggling to find the config files when Cura won't start, look for %APPDATA%\cura\4.9
    Guys its shame to have such Freeze in such App !!! i was so mad from my PC When i'm unable to open it !! and its not from my PC its from the coders!!!
    how do you fix this? im still now sure how to find a fix
    The first post in this thread outlines the way to fix this issue.
    Once you have fixed it, a way to prevent the issue from happening is not logging in to an Ultimaker account, or making sure Cura can access the internet.
    Fixed my problem, thank you.
    This has been fixed in Cura 4.10
    This worked for me. Thank you @Effin for posting , and thank @rknobbe for posting where to find the cura.cfg file.
    No it isn't. This is happening to me on just about 1/2 cura startups on 4.10. Delete config line > starts up fine > log in > locks up again > delete > works > log in > hangs again.
    Rinse & repeat indefinitely
    Posted (edited) · Cura 4.9 startup freeze "initializing build volume" + fix
    At least one bug was fixed. It could be that there is another bug. But to fix that, we need logs.
    Edited by ahoeben
    Feel free to tell me how to get them or which ones. But it'll be pretty hard to get startup logs if it hangs on startup.
    See https://github.com/Ultimaker/Cura/#logging-issues
    I ve dealing with this issue in CURA 4.11 for some hours not finding the answer yet! Unistalling and installing it again and again.... tha abovementioned line in the config file, does not even appear. :(
    Any ideas?
    1 hour ago, FedePonzio said:
    Any ideas?
    Not without logs.
    It looks like you are having a different issue than the topic starter, because that issue was specific to Cura 4.9.
    Edited by ahoeben
