1) Correct. It won't physically tighten anymore, but only minimally moves the plate away from the nozzle.
2) I've had it for four days and it's been like this since I unpacked it.
I raised the bed and confirmed that the limit switch (assuming you mean the microswitch at the very back of the bed, which makes contact with a descending screw) is free of any obstructions.
gr5 2,097
1) So you are saying the screw is as tight as it can get?
2) Is this a brand new printer or was it find for a while?
If #2 is true, there could be something interfering with the Z limit switch. Raise the bed with your hands and look under - there should be a screw or something sticking down I think (I don't know the UM2+C very well). That screw should go into a hole I think that triggers the Z limit switch. If a tiny piece of plastic falls into that hole then you get the symptoms you describe.
