Thanks gr5, checked the settings and the box is unchecked, Im not sure where to go from hereG code.pdf
I have noticed that when I load the model onto Cura, the model loads to the front left corner. Is that normal?
No. Right click and see if you can "unmerge" and/or "ungroup" the model and then get rid of any other stuff. There's likely something in the STL file that you don't consider to be part of the model - over in the opposite corner of the build plate perhaps - you might be able to see it or it might be invisible.
Once you have unmerged, drag your part to the center.
If that doesn't work try the "split model into parts" option in "mesh tools" (first you have to install the mesh tools plugin and restart cura). You use that from right click menu also.
gr5 2,330
In machine settings for your printer uncheck the box "origin at center". Also make sure "x (width)" and "y (depth)" values are correct.
