Posted · Set up a multi material profile
Hi 3d Printing enthusiast,
I've recently purchased the Ultimaker S5 Bundle. After a while of printing, I started to improve efficiency, quality and reliability. I came up with a profile that works perfectly for PLA, but only when both extruders are set to PLA, so when I want to print different materials, such as TPU and PLA, the changes in the PLA profile will also affect these of the TPU and printing TPU with speed up to 100mm/s isn't a good idea.
So it there a way, when only PLA is selected, that the profile changes setting such as print speed (in / outer wall )(print temp at layer 0 ) and so on will change.
Like the predefined settings. (Default->Fine-0.1mm)
Programming a file would also be possible ( syntax needed)
All filaments that are used are from Ultimaker.
Thanks in advance and best Regards
MSPrinting
