PVA difficulties
Posted · PVA difficulties
After using the PVA I realized how great it is for designing complicated parts. Especially designs where there is hollow cavity inside which is hard to reach from outside.
Convinced my boss to buy BB 0.4 hot end and multiple PVA filaments. After using it couple of times, it was very obvious that I can't leave the filament outside as it seems to clog the nozzle. Convinced my boss to another filament and BB 0.4 hot end, within a two weeks it became clogged as well. Now started to take issue of moisture seriously and started to put rice in bags with the filaments and kept them sealed for at least two days before use. Convinced my boss to buy another new BB 0.4 hot end. Right after first print the new nozzle is clogged.
Now I have three clogged BB 0.4 hot ends and 4 spindles of PVA and my parts are not done!
Is anyone else having these issues with Ultimaker and PVA? How are you unclogging the hot ends? The methods usually seems to be the following:
  1. Heat up the nozzle, push and pull a cleaning filament.
  2. try to take out the nozzole from the hot end.
Is there any other way that I am missing?
Thanks
Bikram
