@glx Nah it wasnt. I spend several hours trying to figure out what that movement was. I thought I was going crazy because I had all the things that would technically move the nozzle out of the way disabled. Buuut I neglected to look in the experimental tab which somehow had wipe nozzle between layers enabled.
glx 21
Just a guess but it looks like when you set a minimum layer time and that it should move away from the print when it can’t maintain the layertime at the minimum print speed. The settings are in the "cooling" tab.
