Thank you. I think I grasp what you mean. Essentially that the walls are fixed so prevent any thickening of the walls, yes? But why then does Cura appear to offer the option at all?
tinkergnome 929
5 hours ago, terrypin said:Essentially that the walls are fixed so prevent any thickening of the walls, yes?
Yes - as i said - the geometry of the part is defined by the loaded model. Cura does not change this.
What you probably call a "box with walls" can also be seen as "cuboid with a cavity"...
The term "wall" has a different meaning in Cura.
Think of a "wall" in Cura as the shell around the given model.
Or translate "wall thickness" to "horizontal shell thickness" if you want.
It's easier to see for models without cavities but the principle stays the same:
tinkergnome 929
That said...
I'm not sure, but you can perhaps achieve something with the "expansion" settings. Perhaps in combination with the scale tool... dunno.
It's no replacement for a proper CAD application, but it's at least ...something 🤷♂️
tinkergnome 929
...because what you've changed is a setting of a printing profile.
It's not a geometry modifier.
Your idea would only work, if the model is a closed box, but not if the walls are already present as geometry.
Cura is slicer and can scale and mirror loaded models, but has no further tools to modify the geometry.
What you want to achieve is a classic task for a CAD-Program.
If the geometry is as simple as it looks like - all you need is a simple cube (of any size).
Then scale it to the correct size and everything else can be done with profile settings (no infill, no top layers, bottom- and wall thickness as you like).
