- 8 months later...
I think this needs to be added but I am unable to find the conf file on the printer to add it.
Connecting to Hidden Wireless Network
If your wireless router doesn’t broadcast ESSID, then you need to add the following line in /etc/wpa_supplicant/wpa_supplicant.conf
file.
scan_ssid=1
Like below:
network={ ssid="LinuxBabe.Com Network" #psk="12345qwert" psk=68add4c5fee7dc3d0dac810f89b805d6d147c01e281f07f475a3e0195 scan_ssid=1 }
tinkergnome 926
Because you don't mention it and the router is new:
Be aware that the printer can't connect to a wifi that works in the 5GHz band. You need to setup a wifi channel at 2.4GHz for Ultimaker printers.
In addition:
Printer is obviously a bit picky about the name of the wifi (SSID):
