Problems with cura not printing some of my model
JOMS
Posted · Problems with cura not printing some of my model
I have made a model of a boat in rhino6 but for some reason when I slice it in cura some parts are left out and I dont know why.
I've tried to simplify the model as much as I could.
But for some reason it always wants to print it, leaving out everything above a certain height and then it continues later towards the top.
(as seen at the front/right)
    Try by activating "print thin walls" under Shell...  if that doesn't work, share the STL-file so we can take a look at it...
    Posted (edited) · Problems with cura not printing some of my model
    I do apologies that model is not the right size i forgot to downscale it and then save it.
    what i had in the screenshot was the same thing but i rescaled the x-axis to 250mm and rotated it 45° so that it would fit on the print bed.
    Edited by JOMS
    Sorry I didn't check the STL but I think the walls are just a little too thin.  Try setting "horizontal expansion" to 1mm just as a quick test and then playing with that.
    Or alternatively, try setting "line width" to smaller and smaller values until it slices.  It's okay to have line width at 75% of nozzle size - print quality won't suffer much.  So 0.3mm line width for a 0.4mm nozzle.
    It does not work because the model has no wall thickness at all. It's a non-manifold geometry and therefor cannot exist in the so-called "real world". 🙂
    I don't know the software you use, but you should read about how to create manifold geometry for 3D-printing.
    For example:
    https://www.sculpteo.com/en/3d-learning-hub/create-3d-file/fix-non-manifold-geometry/
    • Like 3
    One is your canoe and one is mine.  Can you tell which is which?
    Attached is the repaired model.  I like Service.netfabb.com for model repair.  They can even float boats and it's free.
    Canoo_fixed.stl
    • Thanks 1
    Oh wow thank you this is great.😄
