WHERE IS MY QUESTION. I WROTE TO YOU YE5TERDAY\\
STEVE MCCCOY
STEVE MCCCOY
I am not sure what you are looking for, you posted yesterday a question which is here:
Additional it would be great when you could check your CAPS LOCK key or SHIFT key and do not post only in UPPER CASE. Thanks!
DivingDuck 94
You can't do it directly, but there is a workaround.
Select the top hierarchy of your design (the first top item) and then print this selection. You can choose parts of your design (bodies, components) by making them visible/invisible.
Same for Save as STL. Difference is, that you have this way the possibility to save multiple bodies/components as a single body file or each body as individual file.
