Looking at second picture and third layer (Z1,9) it seem to start at X75,762 and end at the same if I read the file correct. Gap is in the X-axis
I assume the last G0 movement is wiping the outer wall
Start outside layer3:
G0 F600 X152.136 Y300.658 Z1.9
G0 F7200 X152.134 Y300.558
G0 X75.692 Y299.462
G0 X74.042 Y299.184
G0 X72.379 Y298.613
G0 X70.834 Y297.777
G0 X69.446 Y296.698
G0 X68.256 Y295.405
G0 X67.295 Y293.934
G0 X66.59 Y292.324
G0 X66.159 Y290.629
G0 X66.014 Y288.882
G0 X66.05 Y162.783
G0 X66.339 Y161.058
G0 X66.909 Y159.396
G0 X67.745 Y157.851
G0 X68.825 Y156.463
G0 X70.118 Y155.273
G0 X71.308 Y154.496
G0 X75.773 Y152.003
G0 X75.762 Y151.903
;TIME_ELAPSED:128.225230
;LAYER:2
;TYPE:WALL-OUTER
;MESH:testram.ipt
G1 F1800 X76.597 Y151.873 E0.33348
G1 X76.675 Y151.87 E0.03115
G1 X151.831 Y151.87 E29.99638
G1 X151.908 Y151.872 E0.03074
G1 X152.743 Y151.903 E0.3335
G1 X152.863 Y151.916 E0.04817
End outside layer 3:
G1 X74.037 Y152.164 E0.12238
G1 X74.685 Y152.042 E0.26317
G1 X74.892 Y152.002 E0.08415
G1 X75.642 Y151.917 E0.30126
G1 X75.762 Y151.903 E0.04822
G0 F7200 X76.362 Y151.882
G0 X76.364 Y151.982
G0 X71.588 Y154.312
G0 X70.118 Y155.273
G0 X68.825 Y156.463
G0 X67.745 Y157.851
G0 X67.069 Y159.102
G0 X66.282 Y161.038
G0 X66.378 Y161.063
G1 F1800 X66.197 Y161.925 E0.35155
G1 X66.089 Y162.795 E0.3499
G1 X66.053 Y163.658 E0.34474
Same part but arc welder enabled makes the code easier to read to me, knowing what is circular and straight motion.
However, I did not save this as a 3mf file and might have moved the model so X and Y positions cant be compared but it seems to do the same:
G0 X73.545 Y149.448
;TIME_ELAPSED:311.739956
;LAYER:2
;TYPE:WALL-OUTER
;MESH:testram.ipt
G1 F2400 E2
G2 X74.459 Y149.413 I-0.984 J-37.645 E0.36507 F1800
G1 X149.613 Y149.413 E29.99559
G3 X155.535 Y150.994 I-0.044 J12.047 E2.47403
G3 X159.519 Y154.780 I-5.816 J10.109 E2.21415
G3 X161.401 Y160.321 I-9.993 J6.484 E2.36047
G2 X161.436 Y161.236 I37.548 J-0.978 E0.36547
G1 X161.436 Y286.39 E49.95167
G3 X159.855 Y292.312 I-12.047 J-0.044 E2.47410
G3 X156.070 Y296.296 I-10.116 J-5.821 E2.21382
G3 X150.528 Y298.178 I-6.487 J-10.002 E2.36080
G2 X149.613 Y298.213 I0.978 J37.548 E0.36547
G1 X74.459 Y298.213 E29.99559
G3 X68.537 Y296.632 I0.044 J-12.047 E2.47411
G3 X64.553 Y292.847 I5.821 J-10.116 E2.21381
G3 X62.671 Y287.304 I10.001 J-6.486 E2.36112
G2 X62.636 Y286.390 I-37.645 J0.984 E0.36507
G1 X62.636 Y161.236 E49.95167
G3 X64.217 Y155.314 I12.047 J0.044 E2.47403
G3 X68.003 Y151.330 I10.109 J5.816 E2.21414
G3 X73.545 Y149.448 I6.484 J9.992 E2.36080
G0 F7200 X74.145 Y149.426
nallath 1,117
What does the g-code look like? At first glance i would also blame coasting.
