ahoeben 1,948
There are extraneous faces in your mesh, see the (small) red parts in X-Ray view:
(I am using Sidebar GUI; if you don't use that plugin, then X-Ray view is hidden in the "PREVIEW" tab)
Under Mesh Fixes, you have "Remove All Holes" enabled. The model seems to slice well without that setting enabled.
