How to Enter
Design an Ornament
Entering a new design
Entering an existing design
Winning designs should:
Be original Creations
Share the creative journey! Include documentation of your design process, giving us a peek behind the scenes. For example, show a screenshot of the model in your design program. Use the Tag Holidays2023.
Make sure your submission aligns with our guidelines and Thingiverse's Terms of Service.
Good luck 🎉
A year after the merger of Ultimaker and MakerBotQQ, we have unlocked the ability for users of our Method series printers to slice files using UltiMaker Cura. As of this release, users can find profiles for our Method and Method XL printers, as well as material profiles for ABS-R, ABS-CF, and RapidRinse. Meaning it’s now possible to use either Cura or the existing cloud-slicing software CloudPrint when printing with these printers or materials
kmanstudios 1,120
Have you checked the feeder tension? If too much it will grind up the filament, too loose and it does not grab enough to feed the filament.
Check to see if the core does not require a hot/cold pull.
That is all I have right now off the top of my head. If I think of more I will amend this post 🙂
