Slicer puting gaps between layers .
shanta
Posted · Slicer puting gaps between layers .
Hi
I just downloaded and ran 4.9_20210511_Ultimaker_Cura-4.9.1.AppImage
Previous version was Ultimaker_Cura-4.9.0.AppImage
Since running the new version both slicers will do the fallowing.
should look link this
Any suggestions as to what went wrong and how to fix it?
Thanks
Shanta
    That looks fine.  You appear to have a VERY thick layer height.  Maybe 2mm?  Try a layer height of 0.2mm.
    I switched to a different filament and the problem disappeared. Not sure but that may have been the problem.
    I went back to the filament setting and it then worked likely due to resetting of the variables.
    I had a feeling it was a new bee problem.
    Thanks so much for the support.
    Shanta
