Can't seem to add Support Blocker - Cura 4.9.1
pjjoh1
Posted · Can't seem to add Support Blocker - Cura 4.9.1
I might be going a little crazy, but I can't seem to add a support blocker.  The aim is to set certain sections of my print to 100% infill, whilst have others at a standard infill.
After I select the model, then press Support Blocker on the Left hand pane and press the image again, I don't get the box appear.  Am I doing something wrong?
Here's a screen recording of what I did:
Am I going mad?
    Posted (edited) · Can't seem to add Support Blocker - Cura 4.9.1
    I should have done this earlier, but resetting Cura by deleting everything in the config folder and starting again fixed this problem.
    1. Help Menu -> Show Configuration Folder
    2. Quit Cura
    3. Delete everything in folder
    4. Restart Cura
    Edited by pjjoh1
    Well it fixed it for that session.  After a restart, it failed again.  Looks like it might be related to the issue where the Model can't be selected by clicking on it that others have reported.
    When the issue is there, you can't just click on the model, it won't become selected.
    When the issue is not there, you can click on the model, it will select, and then you can click on the other things like the support blocker and it will work.
    ok, progress.  Issue is really around not being able to select the model.  When Cura is on my Macbook's primary screen, everything works.  When Cura is on my secondary screen, I can't select the model by clicking on it, and hence can't place the blocker.
    Running a Macbook Pro 16" 2019, macOS Big Sur (11.4)
        • 9 replies
