PCB cooling duct
Posted · PCB cooling duct
The air duct for the electronics didn't arrive with my kit. I have made do with some well directed blue tape but would like to make a proper one.
Does anyone have a design for a replacement. All the ones I have found so far are for the extrusion head.
I would prefer to print one but a laser cut is fine.
Thanks,
Robin
    The missing electronics air duct shouldnt be a big problem for the steppers when they still have cooling fans on then. However, they will overheat much less if you add air to the mix. I know that on thingiverse you can find an older lasercut design of the machine, maybe you can find the cooling duct there. Or contact support, tell them that you are missing one and they will send you a replacement.
    PS: Do you have a kit with the new "quality label"? The number on there can help finding the person responsible for your missing part.
    50 lashes for the offending person? :mrgreen:
    +1 :D
    The rotary fan on mine was loud as hell. I replaced it with a 120mm fan, that is placed directly underneath the drivers and blowing upwards. So far, none of them blew.
    I heard from Erik that the heatsinks will do the job most of the time, but as a safety precaution for hot summers/basements they added an extra fan that cools everything down to room temperatures.
    Running without fan can be done, but is not adviced.
    If you overheat the steppers you will get very funny prints/bird nests, but other than that, no harm done. The chips have a overheating protection built in.
        How to Enter
        Design an Ornament
          Entering a new design
        Entering an existing design
        Winning designs should:
        Be original Creations
        Good luck 🎉
        • 1 reply
        • 14 replies
