order of brim lines
Dim3nsioneer
Posted · order of brim lines
I'm just printing a two-piece-model, one piece after the other, using a 15 lines brim. The first brim was printed 'normal' beginning with the outermost line working itself to the center.
The brim of the second object however was printed in a strange way. First the three or four innermost lines of the brim were printed, then the outer lines working from the inside to the outside.
I can't remember having seen this before (maybe I was just blind up to now). Can anybody else confirm this effect? I would prefer to have any brim printed from the outside to the inside due to priming the hotend.
I'm using Cura 13.12.
    I havent really looked at this... I always thought my brims started on the outside.. then carried inside and upwards... have to look at a fresh brim print tonight and pay attention this time ! ;-)
    Ian :-)
    Yes, this is a known issue. The problem also happens with delta-bots which start in the center of the bed instead of the corner. Still need to fix it.
