same problems...in addition to all others mentioned in different foruns
Cura 14.01 solved the right side calibration problem (metal clip), but , when I tried to print a minical test, the fun hited the back and the left metal clips.
During printing, the fan shroud should never hit the clips, because the clips shouldn't reach up high enough to interfere with the fan; you may need to bend your fan shrouds up slightly to ensure that they don't hang below the level of the horizontal piece of the shrouding where the nozzle is.
I haven't tested an abort yet but I just now finished a print and my printer reset itself after the print was done. The print worked as expected, it showed both temperatures as it was cooling down (YAY!) for a few seconds and then *click* restart. Very strange.
I made a mistake and put the wrong firmware initially in the download. If the download if from before 13:30 dutch time, you should download it again. I hoped nobody grabbed the wrong version, but I guess I was wrong.
We're too fast for ya Daid! Thanks, will re-download.
will, redownload. thanks.
Fan problem solved. Now, aparently, I am getting a midcac test similar to the one that came im the box.
I reinstalled the firmware and everything seems perfect now. Problem resolved, thank you!
Sebastian
Looks like this bug can still happen, on it right now!
I've found and fix the bug (and feel a bit stupid now), a new version is online!
IRobertI 502
