GregValiant 1,112
- Make sure "Ironing" is turned off.
- Increase the the "Line Width" to 1.05 or 1.1.
- Print a second pair so the layer time is stretched out.
- Increase Minimum Layer Time. This will slow down the print head.
- Make sure the cooling fan is running at 100%. You are pushing a lot of material and it has some thermal inertia and doesn't cool as fast as it would with a smaller nozzle.
You might want to play with "Lift Head". I haven't used it but I believe that cases like this are what it's for. Could be stringy though since it's a glorified Zhop.
Speckles 1
There is a spiralize mode, if you are willing to print the two separately? Otherwise I will leave this to the experts 😅
