@ctbeke I'm having the same problem with both my UM3 and UM3E. Trying to troubleshoot the UM3 now. Did a factory reset. Connected to wifi. Will not connect to digital factory at all.
I've attached the log files. I've also tried connecting via my phone and browser, neither work.
ctbeke 133
It's possible something went wrong during the connection flow. To help you further I need some printer logs, which you can export to USB from the printer's display and then upload here to send to me via a private message.
Some steps you can try as well:
* Has the printer been connected to the cloud in the past? Disconnect the printer via http://192.168.10.102/cloud_disconnect and then try the connection workflow again.
* Try a [Connect Reset] or [Factory Reset] via the printer's settings menu and then try the connection workflow again. This should remove any inconsistent data that could cause the connection flow not to work properly.
Chris
