Posted · S5 maximum real-world build dimensions?
All of the specifications that I can find on the S5 give the x-y dimensions for the build as 330x240mm.
I've also verified that the machine settings on Cura are indeed 330x240mm.
However, when I try to load a .stl object with x-y dimensions of 310x220mm (20mm less in both dimensions) the object is 'grayed out' with gray and yellow bars and Cura refuses to slice it.
What am I missing here?
    Thank you!
    I did not think of it, but I had 'brim' selected for a previous much smaller print and did not think to change it.  Changing to 'skirt' removed the grey-out.
    I guess this can be closed as resolved.  😉
