Posted · Need help with grooves in surface
Hey,
i have some problems with my last print. The surface of the inner circle is nearly perfect.
BUT the outer ring and lower surfaces are as bad as you can see in the pictures.
Is there a quick fix by settings possible?
Thanks,
Mike.
