problem in cure when wanting to change filament color
Posted
· problem in cure when wanting to change filament color
The message "There are no layers to show..." is because you have either not loaded a model yet, or because you have not clicked the blue "Slice"-button on the lower right of the window. The model has not been turned into gcode yet, so the preview-mode has nothing to work with.
This video shows how to print with two colours. It's a little old now and the interface has changed slightly but I think you'll be able to figure it out:
A year after the merger of Ultimaker and MakerBotQQ, we have unlocked the ability for users of our Method series printers to slice files using UltiMaker Cura. As of this release, users can find profiles for our Method and Method XL printers, as well as material profiles for ABS-R, ABS-CF, and RapidRinse. Meaning it’s now possible to use either Cura or the existing cloud-slicing software CloudPrint when printing with these printers or materials
IRobertI 517
