Hello Torgeir
thank you for the link to the video. It's a bit frightening but as the filament won't move at all inside the tube I don't see how to get it out otherwise. Meantime I will have a look in my wallet, maybe I have to buy a new core.
BTW: The red PVA is Formfutura Atlas (PVA based). I feel that Ultimaker PVA became more and more brittle over time as I mostly print only the support interface with PVA. So a 1 kg spool lasts to long. And also it seems to stick better on PETG that I use most time.
Rainer
Torgeir 228
Hi @r_moeller,
I've never used red PVA, however if the PVA is melted stuck inside the tube, you may need to disassemble the core.
It might be possible to separate the "cooling cylinder" from the brass heating block without damaging the fragile tube connected to the nozzle/heat block. If this can be done safely, it may be possible to boil the PVA out of the tube as it will be dissolved easily in hot water.
However, look through this video before starting disassembling the core.
Someone else might have additional information about this problem.
Only the unit disconnected from the nozzle/heat block is to be boiled, the cooling radiator and tube.
See this video for more info about details to do this, here:
https://www.youtube.com/watch?v=Ln_tMz8Dwd0
Have a look at this video from: https://www.thegr5store.com
@gr5, is a member and a moderator for this Community and I'm sure he might chime in here for further assistance if you'll need so..
Good luck
Thanks
Torgeir
Edited by TorgeirMore info.
