Hi Sander. Thanks for your reply!
I have checked everything, but there is no filament stuck anywhere...
Hi @martijnc80, if you followed the instructions to check the system and decoupler, but found no material I would recommend you to get in touch with our support team. You can submit a ticket via this link! Good luck!
SandervG 1,520
Hi Martijn, thank you for your message and welcome to the community! Is it possible that a piece of filament is stuck somewhere in the bowden tubes connected to Bay A? Please visit this article for help how to check and possibly resolve.
I don't think you should manually try to feed material when your machine is powered off, always use the options in the menu to load or unload material. It automatically unloads material after a print is finished so it can pick the correct material for your new print job when you send one. Hope this helps!
