1 minute ago, gr5 said:The difference is that if you were able to change line with it would also put the lines 0.3 apart whereas with flow at 75% the lines are still 0.4 apart (but 0.3mm "wide").
That is exactly what i want to fix. I see the gap between lines as a big problem.
I dont want to control line width with flow, also I think its possible to make very interesting things with these options i proposed.
They look easy to do, but sometimes simple things can be very hard.
gr5 2,071
Changing line width to 0.3 is very similar to setting flow to 75%.
If you go to the "experimental" section of settings and check enable bridge settings, now you have many more choices including bridge skin flow. I see that it defaults to 60% which isn't much different than the 75% you liked.
