Takei - after you fix the 3rd fan I recommend you do "change filament" and try to get the filament out. If there was a problem related to the 3rd fan the symptom is that the filament partially melts a little above the nozzle and gets wider and causes clogs there in the upper portion of the print head. If you do "change filament" and it comes out easy then probably your underextrusion is something else.
Note also that the 3rd fan should come on the moment you turn on power. If instead one of the side fans come on then just change the connectors around until the rear fan comes on first. The 3 fans have red/black wires leading up to the area that illuminarti discusses in his post above.
illuminarti 18
The first thing to fix is the fan in the print head. There is supposed to be one unused cable at the running from the electronics board to the print head - that is probably not an issue.
Pull back the netting around the wires at the print head, and look for the pink/blue cable pair. That should go to the rear fan. Make sure it is properly connected at both the print head end, and the electronics board end. It seems there are two possible places it can connect on the board.
If it is on the back of the board at the short end, then note which pins it goes to, and try rotating it 180 degrees to reverse the polarity.
Fixing the fan will probably fix the under-extrusion/clogging issues.
Regarding the sliding rod, you need to push it all the way in, to the 'correct' position. You should then find that there is a gap between the pulley and the spacer next to it, and the bearing in the wall of the printer. This gap is what allows the rod to slide. You need to undo the fixing screw on the pulley by the gap, and slide it, and the spacer closer to the wall, and then tighten the pulley really tight again. This way the pulleys on each end are locked in place, and the rod cannot slide about.
