@GregValiant Unfortunately, I couldn't figure out this tool. I only managed to getting it up and running.
In any case, what should I do in theory? I know that the skip always happens along the y-axis, so should I change the Y jerk setting? Or is it something else? I just don't know where to start.
Here is the relevant output from M503:
Recv: echo:; Maximum feedrates (units/s): Recv: echo: M203 X500.00 Y500.00 Z6.00 E30.00 Recv: echo:; Maximum Acceleration (units/s2): Recv: echo: M201 X3000.00 Y2000.00 Z60.00 E10000.00 Recv: echo:; Acceleration (units/s2): P<print_accel> R<retract_accel> T<travel_accel> Recv: echo: M204 P1500.00 R1500.00 T3000.00 Recv: echo:; Advanced: B<min_segment_time_us> S<min_feedrate> T<min_travel_feedrate> X<max_x_jerk> Y<max_y_jerk> Z<max_z_jerk> E<max_e_jerk> Recv: echo: M205 B20000.00 S0.00 T0.00 X8.00 Y8.00 Z0.40 E5.00
GregValiant 1,112
Greg's Accel and Jerk Tool for Windows. Unzip and run the Setup file. It's unsigned (because I'm cheap) so you may have to fool your anti-virus to allow it to install. When it starts you may have to manually enter the port number. As a bonus, there is also a utility for printing from the SD card but running things from your PC.
Enter your build plate size in the boxes at the upper left. Start out SLOW. At high Accel and Jerk and allowed speeds of up to 400mm/sec - some printers can hurt themselves.
Edited by GregValiantLink to post
bassamanator 1
@GregValiant I'm willing to boot into Windows for this! Thanks!!
I will report back my results. Thanks again!
