A workaround is to rename the stl file always to the same file and use the F5 feature where it reloads the STL files. I mean this saves you a lot of time positioning blockers and such.
Then after slicing save the resulting gcode file to match the correct version name/number.
gg48gg 0
I run into the same issue. I basically need an option to "reload from file". I worked around the issue by just using the same stl file for all versions and keeping my versioning in my CAD software, but in my case right now, I decided to move the folder with my scratch stl files and there is no way to point CURA to the new location of the model file.
