UM S5 Capacitive Sensor Tray/Fan Bracket has Loose Sheetmetal Part [SOLVED]
Posted
· UM S5 Capacitive Sensor Tray/Fan Bracket has Loose Sheetmetal Part [SOLVED]
Never mind, I realized that the silicone sleeve has long, thin tabs that surround this sheet metal part and hold it in place relative to the holes in the capacitive sensor tray.
CalebPetersenPhD changed the title to UM S5 Capacitive Sensor Tray/Fan Bracket has Loose Sheetmetal Part [SOLVED]
A year after the merger of Ultimaker and MakerBotQQ, we have unlocked the ability for users of our Method series printers to slice files using UltiMaker Cura. As of this release, users can find profiles for our Method and Method XL printers, as well as material profiles for ABS-R, ABS-CF, and RapidRinse. Meaning it’s now possible to use either Cura or the existing cloud-slicing software CloudPrint when printing with these printers or materials
CalebPetersenPhD 0
