4 hours ago, kmanstudios said:Are you working in Millimeters? Always work your native file in mm.
It's better but has this
test
Blender set to MM units.... 200MM cube created
Cura says too small scaling up size is 5MM scaled up to 2500%
Blender same saved cube in OBJ
Cura: object too small scaling up size 0.2 scaled up to 100%
Before change to MM
Cura file corrupt etc. or scale up
Changed to MM
Cura recognized the object but size is not accurate
Uninstalled Blender plug-in from Cura No change on before and after
Some progress is better than none
kmanstudios 1,120
