Finetuning with CURA and BL-Touch
omexlu
Posted · Finetuning with CURA and BL-Touch
Hello,
I installed BL-Touch yesterday on my Artillery Genius, how can I set within Cura that the Nozzle is heated only after the ABL (after "G29").
Because currently I have the problem that during the ABL ("G29") constantly runs filament from the Nozzle.
Thanks in advance.
    Cura checks if you add a heatup sequence in your start gcode. If you don't, it adds its own heatup before your start gcode. If you don't want Cura to add these lines, make sure your start gcode contains lines which have {material_print_temperature_layer_0} and {material_bed_temperature_layer_0} in them respectively (exactly as typed, Cura will replace the {}-text with the temperatures). eg:
    G21 ;metric values
    G90 ;absolute positioning
    M82 ;set extruder to absolute mode
    M107 ;start with the fan off
    ; etc
    M140 S{material_bed_temperature_layer_0}   ;Start heating bed
    M190 S{material_bed_temperature_layer_0}   ;Wait for bed to reach temp before proceeding
    M104 S{material_print_temperature_layer_0} ;Start heating extruder
    M109 S{material_print_temperature_layer_0} ;Wait for extruder to reach temp before proceeding
    ;etc
    Having this in your start gcode prevents Cura from putting heatup commands in front of your start gcode. This means that you can insert your ABL command anywhere you want to relative to your heatup commands.
    As @ahoeben says, if Cura notices the Keywords it won't add temps before your Startup Gcode.  But some folks prefer a bit of preheat before ABL so something like this would heat the hot end a bit, start heating the bed, do the ABL thing, and then heat up to operating temperature.  AHoeben's list of Cura Keywords is HERE.
    ; Custom Start G-code
    G21
    G90
    M82
    M107
    M140 S{material_bed_temperature_layer_0} ;start heating the bed to operating temp but don't wait for it to get there.
    M109 S150 ;heat the hot end to some temperature just below "drool" temperature.  Wait while heating.
    G92 E0 ; Reset Extruder
    G28 ; Home all axes
    G29 ;your ABL command
    M109 S{material_print_temperature_layer_0} ;Wait for hot end to get to operating temperature
    M190 S{material_bed_temperature_layer_0} ;wait for bed to get to operating temperature
    ;you can add purge lines here
    ;End of Start G-code
    Since there is some expansion of the heat block, nozzle, and bed when they are hot then having them at an elevated temperature during AutoLevel can increase the accuracy of leveling.
        • 6 replies
