How to extrude outer wall perimeter in one continuous extrusion?
Posted · How to extrude outer wall perimeter in one continuous extrusion?
Hello,
I designed a rocket in Solidworks and have broken every one so far.  Version 3 survived 120 PSI launch twice!  Super fun.  One of the most common failures are the fins breaking off during launch or landing.
Here is a layer near the bottom.  The preview shows that it prints the cylinder first, then each fin.  I think it might be stronger if the fins were connected to the cylinder in the same extrusion path instead of printed after the cylinder.  I was wondering if there is a setting in Cura which would make the printer trace the very outer-most perimeter in one continuous movement?  Like it would go around one third of the cylinder, then out to the end the fin, back in, around the next third of the cylinder, etc..
Any feedback greatly appreciated!
Thanks
    Posted (edited) · How to extrude outer wall perimeter in one continuous extrusion?
    Why not make the fins thicker where they are connected to the body?
    Edited by Mari
    It looks a little bit strange, because from the sliced preview it looks like the fins are not connected at all. So double check your model, I guess there is something "wrong".
    If not I would try to put a small fillet in the corners.
    I agree with Smithy above.
    Drawn a quick "mock-up" and created an .stl this is what it should look like, also added some Rad to strengthen the fins.
    The GREEN arrow shows the "Start Point" - As you can see there's only 1.
    Your model shows 3, which suggests it's not connected.
    Thanks for the replies!  Carbon that is exactly what I'm hoping for.  When I used the boss/base to fill in the fins it must not have merged them to the body.  I've been trying to add a fillet but it doesn't seem to let me fillet a curved body to the cylinder.  Back to the drawing board! Thanks everyone.
    You are welcome!
    And we always like to see the printed result in the end, so would be nice if you can post a picture of it 🙂
        • 6 replies
