Posted · Merged Models Gap Between Solids
Hello: I have noticed a small issue which is creating a weakness in my thin parts where the two materials join (I am printing two colours of PLA). If I slice the model in any version of Cura (I have tried 4.7 through 4.10) I have noticed a bit of variance in the initial layer for both extruders depending upon the adhesion type selected, notice the gap between the B and the stick, the only change made between screen captures here is the adhesion type. My goal is to have the two models connect as in the second image with the adhesion type set to Brim but I do not want a brim on the print as removing it destroys the print. Any ideas?
Thanks!
Skirt.thumb.JPG.dab1db5f86377c0a90a55d348a41dac0.JPGBrim.thumb.JPG.937adce0e0037607a7791ff18b9538f0.JPG194889191_NoAdhesion.thumb.JPG.d0709bf35031e373459d48be8d191340.JPG
    Cool that seems to have done the trick for me, thanks!
    I am curious if the behaviour noted above in my original post is expected or if it is a small bug in the slicing?
    It isn't likely a bug in the slicing.  The letters aren't connected to the strip below them.  A setting like "Initial Layer Horizontal Expansion" that @Smithy is talking about is usually set to a small negative number to reduce elephant's foot and can cause what you see there.  If the models had been merged then that wouldn't happen and there would not be "outer walls" between the letters and the line thingy.
    If you zoom in to the mid-line of the letter "B" in the first screenshot you can see that there are two Outer Walls with no extrusion between them.  The same area in the second screenshot shows two outer walls and two inner walls between them.  I'm guessing that something was going on with one of the horizontal expansion settings to cause that.  It's an effect that shouldn't have been caused by simply going from skirt to brim but a change in profiles could do it.
