Send a Pause print to Ultimaker S5 over network, possible?
Posted · Send a Pause print to Ultimaker S5 over network, possible?
Hi All!
i am trying to send a pause print to my UM S5 over a local network from my PC, and for my application I don't want to use the Digital Factory or third party software for this command, i have looked into The local API possibilities but no Pause POST/PUT command can be found in the docs.
does anybody know if it is possible to send a Pause command over a local network?
Thanks a lot!
cheers,
Jos
    As far as I know you can only put the pause into the gcode itself with a post processing plugin in Cura. But there is no way to pause the print manually over the network.
    A ver theoretical idea is to put the printer in developer mode, ssh to the printer and send the gcode command directly from the console. But not sure it it really works.
    One can use the API of the printer in a local network. The following  topic contains a working example:
