The UM2+C has the feature to manually pause a print via the printers menu, so it should also be possible to do it via gcode, because as far as I know the menu feature does exactly the same and sends an command. Manually it works, I just tested it.
But I can remember there was a problem with pause at layer, this was not working for me when I tried it some years ago, but pause at layer height in mm worked. So please also try it with height instead of the layer number.
gr5 2,099
@Smithy - does UM2+C have pause feature?
I think UM3, S3, S5 all have it but not sure about UM2+C.
