Posted · Temp not right later in prints Cura 4.8.0
I'm at wits end with a problem. I have 5 tenlog hands 2 machines. I'm printing some models that ranges from 3 inches high to 5 or 6 inches tall. The shorter ones print perfect, however, once I get up to, say, 3 inches the prints are failing. I noticed the hot end temp is running at 175 instead of the 205 that it is set for. Same with another machine runs fine to a point then fails and I seen the temp of the hot end trying to print at 160 and in cura I have this to run at 205. Connections to the heads are fine. I'm using Cura 4.8.0. Is there a setting that is causing this? Since it is happening on all my printers? I have had failed prints for a week now and don't know where to go.
H2_boom.gcode
    I think I found the problem. There was a script running for a temp tower that was doing that temp adjustments to my prints. Ugh!
