27 minutes ago, gr5 said:I'm pretty sure it's because the model is too thin there for your settings.
As a quick check - set the nozzle width to half of what it is now to see if that helps. If it does then it is related to those thin areas of your model.
You can also try the option print thin walls. Check that box in cura. If that's not enough try lowering you line width parameters. If your nozzle is 0.4mm you can go down to 0.3mm line width without a severe loss of quality. Certainly 0.35mm is fine.
As a general rule, any wall you print needs to be 2X the width of the line width parameter. Or at least 1X if you check print thin walls.
If I'm completely wrong and this makes no difference then please post your project file (do menu "file" "save project..." and post that here).
This totally makes sense because I forgot to made those spots thick enough! Will give few tries and then update back. Thanks a lot!!!
gr5 2,094
