Posted
· Cloud / Digital Factory Usage Model Alternative?
The UM product line is not cloud only, that's wrong. Every UM printer can print directly from SD card or USB stick. Nearly every printer which is network enabled (ethernet, wifi) can also be used to directly send the print job from Cura to the printer - locally, no cloud. An exception is the UM2+Connect, this printer can only be used via the Digital Factory (Cloud) or USB stick. But with every other printer it is up to you if you want to use the printer locally, fully isolated if you want or if you want to use the cloud. Both is possible and if you want, also both together. So if you connect the printer to the cloud, you can decide in Cura if you want to print directly, print via cloud or save the gcode to USB.
I'm excited because I've personally produced this showcase event, so if you are curious what else I'm up to nowadays, come check it out and say hi in the chat! It would mean a lot!
Smithy 1,088
