@TheoM Thanks for the info that you experience this problem with the standard UM3 model.
This means the problem was reported on both normal size UM3 and Extended UM3 printers. Weird and frustrating is that we can't reproduce the problem on our testing printers which makes it difficult to fix this problem.
1
Top Posters In This Topic
15
5
3
3
Popular Days
Aug 5
11
Aug 18
7
Aug 4
5
Aug 25
4
CarloK 15 posts
gr5 5 posts
Morandir 3 posts
V3DPrinting 3 posts
Popular Days
Aug 5 2021
Aug 18 2021
Aug 4 2021
Aug 25 2021
Popular Posts
CarloK
@V3DPrinting You are right. My printer is modified and I tend to forget it's an unofficial feature. @Enigma_M4 Yes, it's possible and works great on my UM3 but not officially and require
SandervG
We’re happy to announce that we’re releasing a firmware update to the popular Ultimaker 3 and Ultimaker 3 Extended. Firmware 5.2.17 will contain: material profiles for the new Ultimaker PETG
CarloK
And there are a whole lot of other changes that didn't make it into the official release notes because those are not applicable to most users. A small list: - copied firmware installation ro
Posted Images
CarloK 196
I discovered what the weird lines are, it is an error message, but the graphical image was created for the display of an S5 printer and fails in this weird way on the UM3.
In 5.2.17 the update routines were replaced by a newer version backported from the S-line printers. The error screen was not converted to the UM3 screen, we'll fix this in a next release (coming very soon).
One of the new features is that we now check for the printer that you install the software on is allowed to run this software. That's why higher up in this thread someone got the screen with lines when installing v6.2.2 for the S5 on his UM3.
Nothing breaks, after power cycling the printer you will still be on your previous firmware version. We are looking into why some UM3 Extended owners experience these problems.
TheoM 1
I am using a UM3, standard height.
I have attempted 2x times. I can shut the machine off (manual power switch) and the machine will turn back on in working order, but with older firmware.
Edited by TheoMLink to post
