I'm sorry, it is a UM3. I was mistaken in the other post and caught my error in this thread. On the front, it says "Ultimaker 3".
@pdihawk - chewed up filament can be caused by dozens of very different issues. For one thing it can be caused by the feeder or the hot end. If the hot end is underextruding the feeder is fighting hard and doing it's best and chewing up the filament a little bit but at some point it gets out of control and bites out a circular chunk and nothing comes out. So it can be either end.
Usually it's the print core. But it could be your feeder is at the wrong tension. Look at both feeders and the tension indicator should be in the middle for PLA. If the tension is too low it can slip more and chew up the filament. It could also be that you ran CF filament through feeder 2 but that is unlikely. CF filament can smooth down the tiny pyramids that grip the filament.
More likely it's something about the nozzle. I'd try some cold pulls - you can do these from the front panel control on the printer. It will give you instructions.
Another thing to try is to just change out the print core. This is the solution that takes the least amount of time and effort (but the most money). Ultimaker considers print cores a "consumable" just like filament. Even if you bought one core every 5 spools of filament it wouldn't be all that significant of a cost.
Got it!
As long as it has been at our company, it hasn't had CF filament run through it.
I unloaded the PLA on #2, removed the chewed up section and reloaded.
I started an almost 3 hour print a little bit ago. The middle fan is spinning and I will see how it goes.
If it keeps having problems I will try the spare print core that we have.
Thanks for all of the help!!
Edited by pdihawk
gr5 1,843
Do you have the S3 or the UM3 as your other post mentions the S3.
