Scaling only one side of X, SOLVED
Lalin1974
Posted (edited) · Scaling only one side of X, SOLVED
Hi guys
Is there a way to scale just one side of the X side? I need one print to be 10 mm shorter, but not completely scaled. Is there a way to focus on one specific side of the X side and adjust it? The way I see it, I can either uniformly scale the whole print by percentage or mm, or tick off uniform and scale X, Y, or Z. But what I want to do is adjust the size of only one side of the X side.
I am still new at this, and have not been able to find a way.
Thanks in advance
Christos
EDIT: I found a simple solution by using Tinkercad.
Edited by Lalin1974
    • Lalin1974 changed the title to Scaling only one side of X, SOLVED
