You might need to change the camera type in the config of the printer. If you have say a VGA instead of a YUC camera.. that would explain. There is another post somewhere here in the community section that explains how to do it.
Anyway, I went with the mirror. Low cost hack and heck I had one laying around.
CarloK 204
The API supports up to 10 camera's. For the requirements: plug it in the front usb, and if it works then you are good.
I don't think there are free USB ports inside, this also might differ on the S5 variant you have (v1 has the robot logo, v2 has the 'U' shape logo on the sides).
The usb supports a hub, you might even move this inside the housing.
Then, recently I learned about this brilliant low tech alternative: stick a mirror to the wall opposite the camera. An IKEA mirror seems to work great. 😎
JTMD 20
I tried this today on my current rev S5 and no bueno. used a brand new USB camera and plugged into the port on the front of the machine.
http://xxx.xxx.xxx.xxx/api/v1/camera/0/stream worked on internal camera.
http://xxx.xxx.xxx.xxx/api/v1/camera/1/stream did not work on anything.
http://xxx:xxx:xxx:xxx:8080/?action=stream worked on internal camera.
http://xxx:xxx:xxx:xxx:8081/?action=stream did not work on anything.
I too, would love to have a much better viewing angle as my machine is in a detached building 150ft away from my house and hiking down there at 1 am isn't my idea of fun 🙂
