I saw rare cases of production issues with the new UM2 nozzle, where a brass shaving would be stuck on the inside of the nozzle. pushing anything from the outside in will only "lift" the brass particle (which may be still attached to the nozzle), while the next printing attempt will cause it to clog the nozzle again.
I would suggest to take off the nozzle completely, clean it out with a hot-air gun and q-tips (like squeaky clean) (and acetone doesn't help you with PLA leftovers, only heat and paper sticks and cotton will do) and see if you find any debris on the inside. if it is really clean, take a small drill bit (i.e. 1-1.5mm) and deburr the inside of the nozzle orifice from the inside a tiny bit (just to take off the sharp edge and ease the flow a bit).
re-assemble, and enjoy printing.
illuminarti 18
I think acetone probably would help - would be worth trying at least; I was about to suggest that, but then OP fixed the problem anyway. It probably depends on how well baked the ABS is; once it gets burned I'm not sure if it is still soluble; but it probably wouldn't hurt to try - but I figured it would be a pain to do, as you'd need to remove the heater and temps sensor I think, and take it totally off the printer.
